Hi
Now I'm probably being lazy here and "yes" I have read the various guides for OCing the 2500K processor (bittech has a nice write up for this board) and all pretty much seem to suggest changing the CPU ratio is the way to go.
Well if I just change the ratio on this board from 33 to 42 and leave everything alone (yes I know voltages are on auto). I seem to end up with a permanent OC of 4.2 (IE. it doesn't appear to down clock under light load back to 1.6) and at 1.36 the CPU voltage is probably a bit high for this OC.
So I noticed a video on YouTube that suggested leaving everything as "default" in the BIOS and simply going to the "CPU feature" section in the BIOS and changing the core ratios (turbo boost I'm assuming here) from 37/36/35/34 to 42/42/42/42.
Well I tried the above and I now appear to have a system as before but the turbo boost just pushes all the cores to 4.2 and voltage under IBT would appear to be a much more reasonable max of 1.288 (IE. well under the max 1.35 that seems to be talked about as 24/7 safe). Temps on all 4 cores hit a max of 60C under standard run of IBT.
I also left my XMS3 RAM to run at 1333 as this appears to use a voltage of 1.5 rather than when running it at 1600, where it uses 1.65v.
Question... is there any drawback to using this extremely simple method of OCing this board/CPU?
I'm not looking for the fastest OC. Just a decent free boost, while maintaining my system as stable as possible.
I'll be interested to hear peoples opinions on this.
