Morning all! Been quite some time since I've been around here, a quick look around would suggest not much has changed which is great
As those of you with good memories might remember, I bought an old accord about a year ago as a cheap runabout. Was hoping to get a year or more out of it, which it's given me now so any time I get out of it now is a bonus really. It's not been at all problematic, had a new clutch a few months back but a mechanic friend helped make that a cheap job! Unfortunately now, the gearbox itself seems to be on its way. It's also getting relatively tatty, with the cyclist dent and some other bits.
So as I've got a few quid aside I'm going to replace it in the next few months, the problem is deciding what to get. Wanting to spend 2-3k, could add a few hundred quid more if something really good comes up. What I'm after
- Some degree of practicality, preferably a hatchback type boot. Not carrying people around, but something I can use for larger loads, tip runs etc.
- Sensible running costs (in terms of insurance, servicing etc)
- Fuel economy not important, minimal miles
- Something "cooler" than a tatty old Honda Accord (this is probably the most difficult requirement!
- Something a bit different/bit of fun.
I had been quite keen on the Hyundai Coupe... yes, I know they're crap compared to the competition but they do everything I want, they look great and are amazing value for money. Problem is, I went to have a nosey at one yesterday and I dont fit properly
. I had read that the driving position is odd and sure enough my head was against the ceiling in any sort of proper driving position.
So, any other suggestions? I did see a Mondeo Mk3 Zetec-S 2.5 within budget locally. Yes, I got bored of my old one (lets not get into that) but at the end of the day they're great cars. Although it doesnt fit the last 2 requirements, those are the ones that arent too important.
Thanks all!
)- Something a bit different/bit of fun.
. I had read that the driving position is odd and sure enough my head was against the ceiling in any sort of proper driving position.So, any other suggestions? I did see a Mondeo Mk3 Zetec-S 2.5 within budget locally. Yes, I got bored of my old one (lets not get into that) but at the end of the day they're great cars. Although it doesnt fit the last 2 requirements, those are the ones that arent too important.
Thanks all!
