Spec check before I click "Buy"
18 Oct 2002
Brighton
Hi,
I've talked myself into an upgrade after my 775 mobo died the other day:
CPU - Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM - £157.99
Motherboard - MSI P67A-C45 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** - £89.98
RAM - Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit - £32.99
Cooler - Scythe Shuriken Rev.B Quiet Low Profile CPU Cooler - £27.98
SSD - OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive - £92.99
Graphics card - MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics Card - £133.99
So, a little explanation and a few questions...
CPU - Seems like a no-brainer, OEM because I don't want/need the cooler.
Motherboard - I would've liked the lucid virtu feature of the Z68 series but I need 3 PCI slots and none of the reasonably-priced ones have enough. I don't need SLI so the cheap MSI board seems like a winner.
RAM - Cheap has always served me well in the past.
Cooler - Need a low-profile one (media centre case) and this seems to get reasonable reviews.
SSD - For C: use only. Not sure whether this is faster than the OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive...?
Graphics card - I'll be gaming at 1920x1080 and the 460 seems like a reasonable bang-for-buck card, don't want to spend a fortune on it.
Any obvious errors with this setup?
Many thanks.
Thanks both of you for the warranty tip, I'll take that as good advice.
I've always been an Nvidia user, I hate being pointed in the direction of an obviously better ATI card :) I'll have to think about that.
Ta.
The spec is spot on, there seems to be some complaints about the Agility3 SSD's , im not sure what its about.
Edit, its something to do with early firmwares not working with certain chipsets.
i put it on a z68 chipset and it was 100% solid
have read that early chipsets and sata 2 ports it doesnt like
