2 x 580's Sli or a 590
19 Oct 2002
Pembrokeshire
Just a quick question before I order. I'm upgrading from an Radeon 5970, would I be better off going for a 590 GTX or 2 x 580's in Sli.
The only 590 card OcUK has is a Gainward GeForce GTX 590 3072MB GDDR5, is that a good card?? not sure about gainward..
Cheers
Jase
P.S. or something completely different like an ATI card again
2 x 580 in SLI is better, if your mobo has got reasonable pcie spacing.
After having been using both 6950CF and 580SLI, I'd say for gamers, the best performance/price ration is definitely 2 x 6950 in CrossfireX, if not limited to the nVidia side.
May I ask what resolution you use?
Currently 590s have a bad reputation due to overheating and reliability issues, so personally I'd steer clear.
I use a res of 1920x1200
my MB is a Gigabyte X58A-UD3R, I don't know much about MB's tbh so I've no idea if spacing is good or not.
I plan on doing a proper upgrade in the next few weeks but in the meantime I thought I'd start with a graphics Card(s)
Assuming I go for a couple of 580's any recommended ones to get, I see there are 1536MB versions and 3072MB versions.. I'm not too bothered about price but don't want too spend more than needed. the Gainward Phantoms look nice but one comment say's they're big.
After looking into the manual of X58A-UD3R (both rev 1.0 and rev 2.0), I'd say this mobo is a BAD pick for multiple dual-slot cards. In order to achieve x16 + x16 setup you'll have to use the first slot and the 3rd slot, which makes two cards sticking together firmly, making the upper card hard to breath (and hence hot and noisy).
Thus you might consider GTX590 in such case, or sell your mobo and get another one with reasonable pcie spacing. (or of course, use the first slot and the 5th slot and live with x16 + x8 hopefully)
(Note 2) For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16_1 slot; if you are installing two PCI Express graphics cards, it is recommended that you install them in the PCIEX16_1 and PCIEX16_2 slots.
(Note 3) The PCIEX8_1 and PCIEX8_2 slots share bandwidth with the PCIEX16_1 and PCIEX16_2 slots respectively. When PCIEX8_1 is populated with an expansion card, the PCIEX16_1 slot will operate at up to x8 mode; when PCIEX8_2 is populated with an expansion card, the PCIEX16_2 slot will operate at up to x8 mode.
Thanks for taking the time to do that, appreciated.
I think I've come up with a plan, it looks like the 580 3072MB will be a better card to go for if Sli. So as I was planning an upgrade in a few weeks anyway, what I could do is buy a 580 GTX now, and then when I upgrade the CPU and MB I could buy the 2nd card. Would you see any problems with this idea ?
Looking on the OcUK site, I like the look of the Gainward GeForce GTX 580 "Phantom" 3072MB GDDR5 PCI-Express Graphics Card. Is this a good choice ?
Thanks again & sorry for all the questions.
a 6990 should be good buy. single card and should last long. Personally i would wait for any refreshes round the conner, your current card is no slouch.
A single GTX580 should be able to handle most games today, unless you wanna play hardware-demanding ones like Metro 2033, Shogun 2, The Witcher 2. I'd say your plan looks reasonable.
Regarding choice of 3GB cards: I'm not familiar with the Phantom one (because I haven't read much reviews/feedbacks on forums). I know that the Palit one is a TRUE dual-slot design, which takes no more than 2 PCIE slots. Meanwhile, the Lightning one is actually a 2.1-slot design, and when you have to make them stick together, the fan blade would stab the back of the next card (see this link). The Lightning one is of course the ultimate 40nm GPU to get.
I'm running a pair of reference cards of 3GB from EVGA. It won't be as cool/quiet as the non-reference cards but it won't dump heat into the case either.
2 x 570 is a bad pick. I have already stated why on #5 of this thread.
Unless you don't play games like Metro 2033/Shogun 2/The Witcher 2 etc. Even with 2 x 580 I still struggle to run these 3 games at 1920x1200.
You are a salesman's dream..
The whole 3gb for 1920x1200 has been stated so many times and its pointless.
It's pointless for those who already own the 1.5GB versions and play at 1920x1200. For new users what can be too wrong to get the 3GB versions to be more future-proof? (I have already stated that the best bang for the buck is 6950 CF but the OP seems not interested at all.) There are already games starting to eat more than 1.5GB there, and enthusiasts spending that premium into GTX580 don't want any bottleneck from vram. Let me just quote the review from hardocp again and again:
Metro 2033 @ 1920x1200 Very High 4X MSAA + Depth of Field
When we lowered the resolution to 1920x1200 something wonderful happened. We were able to play at Very High, with 4X MSAA and we were also able to finally turn on Advanced Depth of Field with it!
The only video card that was playable at these settings was the MSI N580GTX Lightning XE video card. It was the only one that felt smooth enough, with enough performance, to play at 1920x1200 Very High 4X MSAA with Depth of Field. There were some upper 20's framerates toward the end, when we had wide vast outdoor areas. However, a lot of this game is underground, and the experiences were not bad at all. The GeForce GTX 580 was almost playable, but it felt a little too laggy for our likes. The AMD Radeon HD 6970 was most certainly not playable at this setting. The clear winner for the best gameplay experience, is the MSI N580GTX Lightning XE.
There's only a gain in 2fps average there, and more importantly 1fps minimum.
How he came to that conclusion about the lightening being the only playable card is dumbfounding.
The price difference on OCUK is £50 too, the cheapest being OCUK's for £450.
Gaining 2fps for £50 is not worth it.
The same argument occurs every few years, buying more Vram does not futureproof your system. So long as you don't change your gaming resolution.
By the time 1.5GB of Vram bottlenecks 1920x1200 the 580 GTX will be collecting cobwebs.
The bottleneck will come the architecture as it ages, not the VRAM.
