3-way SLI N/A
The MSI doesn't support 3-way, IIRC 3-way is only supported by NF2000 chip, which the MSI doesn't have I don't think - link
ATI CrossFireX™ is the ultimate multi-GPU performance gaming platform. Enabling game-dominating power, ATI CrossFireX technology enables two or more discrete graphics processors to work together to improve graphics performance. ATI CrossFireX technology allows you to expand your system’s graphics capabilities. It allows you the ability to scale your system’s graphics horsepower as you need it, supporting up to four ATI Radeon™ HD graphics cards, making it the most scalable gaming platform ever. With an ATI CrossFireX gaming technology, the traditional graphics limitation exists no more, allowing you to enjoy higher performance as well as visual experience.
I want 3 cards in trifire.
Preferably 2x16 and 1x8 if that's possible?
Look at the specs. of the motherboards I listed.
You won't notice the difference between x8 and x16 anyway.
The msi one is a beast lol. Thanks mate. Now to read reviews
Don't forget to choose your case carefully if you get one.
It's bigger than a standard ATX board.
Will the corsair obsidian 800d be big enough?
Not really.
You need a case with 8 expansion slots instead of the normal 7.
Somethng like the HAF-X.
I just read a review on this board. No tri sli support. This mean no trifire support?
No n200 chip.
Completely different things.
No NF200 chip means no more than 2 cards in SLI.
That has nothing to do with Crossfire.
From MSI's description:
Looking to have a i52500k and 3 6970s trifire.
Would like to over clock the i5 as well.
Which us a good 1155 based motherboard for this?
Z68 or p67
Thanks in advance.
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
The forum Dons/Admins reserve the right to judge individual signatures, particularly those deemed to contain material of an adult or offensive nature. If the Dons/Admins think the signature is unsuitable for a family orientated forum, then it will be removed. If the user then replaces it without making changes, they will be suspended.
