pc v350
9 May 2007
hi, basically i going to remove the pop rivets from it to dissemble a lian li pc v350, but looking at the rivets their a bit flat.
so i was wondering if any one had done it and gotten replacement rivets or did you just use the regular ones and bulge out a bit.
also some how i lost a couple side panel screws =/ any one know what thread sizes are they?
