If you mean the NZXT H2 White, I think the Define R3 would be the better bet. By all accounts the H2 isn't too bad, but the R3 is generally better overall.
If you do go for the R3 you should be aware that recently quite a few have been turning up damaged in transit. Once you receive it, give the case a thorough once-over for damage, just in case.
the h2 has horrible build quality - they just fall apart when you touch them :/.
Fractal all the way im very pleased with my R3
As above I assume you mean the H2 in which case I'd recommend the R3, got myself a black one a month or so ago and it's an amazing case, luckily it didn't turn up damaged either.
Take a look at that H2 vs R2 comparison video, the H2 looks cheap and nasty.
R3 > H2. As above, the video they have posted I have posted many times. Go with the R3.
Doesn't stop it from being a rubbish video.
