560ti or 6950?
Depends what you play.
at the moment I play a lot of Rift, which made the 560ti a better choice for myself.
yeah I tend to play a lot of fallout new vegas, Crysis 2 and I'm starting to play mw2 and Mirrors Edge, but I also want to get Skyrim, BF3, MW3, Duke Nukem and Dirt 3
looking at benchmarks the 5870 is screaming out at me as it is only slightly less powerful than the 6950 and more powerful than the 560ti in most games and is cheaper than them both as I can get it for £150 new! and also if I want more power I can add another in xfire with my current as they reach 598w at load in furmark :) (I have an XFX XXX 650w)
Maybe even better value if you can live with xfire is two 5850 at £99 each?
£150 for a 5870 or £198 for 2 5850's...
Just be careful you dont regret multi gpu set up's I personally hate it, other think its good value.
Just throwing my hat in to the ring.
After going from a 5870 to a 2Gb 6950>70 I can tell you that benchmarks can be quite misleading, they don't tell the whole story. The 6950 has a much smoother game-play experience than the 5870.
A discussion about one card that appears according to the figures to have slightly better performance from another same series card (albeit less vram):
http://forums.overclockers.co.uk/showthread.php?p=19357039#post19357039
Metro 2033 @ 1920x1200 Very High 4X MSAA + Depth of Field
When we lowered the resolution to 1920x1200 something wonderful happened. We were able to play at Very High, with 4X MSAA and we were also able to finally turn on Advanced Depth of Field with it!
The only video card that was playable at these settings was the MSI N580GTX Lightning XE video card. It was the only one that felt smooth enough, with enough performance, to play at 1920x1200 Very High 4X MSAA with Depth of Field. There were some upper 20's framerates toward the end, when we had wide vast outdoor areas. However, a lot of this game is underground, and the experiences were not bad at all. The GeForce GTX 580 was almost playable, but it felt a little too laggy for our likes. The AMD Radeon HD 6970 was most certainly not playable at this setting. The clear winner for the best gameplay experience, is the MSI N580GTX Lightning XE.
There's only a gain in 2fps average there, and more importantly 1fps minimum.
How he came to that conclusion about the lightening being the only playable card is dumbfounding.
The price difference on OCUK is £50 too, the cheapest being OCUK's for £450.
Gaining 2fps for £50 is not worth it.
Most fps numbers measured by review articles are based on 1-second time intervals, and you wouldn't be able to tell from these numbers if there are lag spikes or not. Such fps numbers are good for most people to get a basic understanding of where the graphics card lies in the queue, but not enough for enthusiasts. For deeper analysis one would have to look into the time gap between each consecutive frames and do some basic statistics, such like how many gaps are there greater than 33ms or so.
That's why every a few years whenever there are cards with more vram, reviews would get similar fps numbers but the description would say the gaming experience is more smooth.
Yeah this is something a lot of people don't understand - the nature of the disposition of frames within a 1 second sample can make a huge difference in how smooth something feels even at the same framerate - something could be only doing 20fps but feel smoother than another GPU at 30fps because the 20fps has a regular gap between each frame of 50ms whereas the one at 30fps could have gaps of 200ms between clusters of updates with shorter intervals and feel absolutely horrid.
Rroff does a fantastic job of explaining what I mean, I would never have pulled that off!;)
The 6950 and 560 are both great cards but the extra vram(which can be a game changer) is the clear winner for me, and as already stated above, close on £200 and only 1GB doesn't make sense imo.
wow thanks for that :) will need to sell my card first to get the 6950 though, also I may go with the reference design 6950 as it means that I can get a fullcover waterblock plus the bonus of unlockability (hopefully I can get one for £200 from a manufacturer like XFX that lets you change the cooler without affecting the warranty :) )
No problem.
Iirc you can't change the XFX cooler anymore, they even put stickers on the cooler screws that tells you warranty is void if removed.
I can tell you that His and Msi revision 1's don't have the stickers on the cooler screws though;).
To be honest, they're both fantastic cards and you'd be happy with either of them, I'm sure.
The 6950s do have more VRAM and the rev.1s being able to flash to a 6970 is a bonus, but the 560s overclock like a beast and 1gb VRAM shouldn't hurt you at 1920x1080.
I'd be tempted by the 560s due to lower prices. A 560 ti can be as much to £50 cheaper than a rev.1 6950.
I've been playing some Mirror's Edge and it was unplayable at 18xmqa (highest AA) iirc so I think I may need more vram?
if your running daft levels of AA like that then yes you might need more Vram, but seriously do you need that much AA?! :confused:
Surely thats going to cripple the performance of the best card out there thats not even considering the Vram.
Right guys I'm back from my suspension :) I didn't really agree with it and now I'm banned from the MM :( but hey on a relevant note I've pretty much decided on that the 6950 would be my best bet just need to save a little more and then I can get it :)
