Best bag/case/sleeve for Macbook Pro?
12 Jan 2008
As title - I'm looking for something stylish but durable. Not too expensive, around the £30 max mark.
Ideally some kind of bag as I will be transporting to and from uni (part-time student). Also.. whilst im at it - are there any must-have accessories for a Macbook Pro; anything you would recommend?
Anything? :)
I've got a Booq Vyper XS for my 13" Pro, they offer bigger sizes to accommodate the 15" and 17". Its semi rigid so offers a lot more protection than a poxy bit of neoprene. Might just be a bit more than your budget but then how well do you want to keep your MBP protected.
I was looking at those, but I'm also trying to find something with a strap as I will be carrying it around all day. Has anyone had any experience with 'incase' cases?
I like my 'incase' case. Had it for my 13" Macbook for two years and no problems. I like it because it really doesn't add much size to the MB and protects it from scratches/knocks. I took it to West Africa with no problems - so it's fairly tough. The neoprene is also good as it's a bit spill-proof.
Bought the incase case in the end - does it's job, hopefully it will last! Not amazed by the padding though, ah well.. should survive as i also have it in a neoprene case :)
Cheers everyone.
I've got an InCase and it's fine, but if I was buying one again I'd probably get a Be.Ez Larobe, just because they're made out of quite firm memory foam stuff which is very good at soaking up knocks, and they're no more expensive than other makes.
Nice quality and they come in loads of different colour schemes
