Hi all, did some tests on my rig today with a power meter, first of all these are my specs:
i5 2500k @ 4.5ghz
Gigabyte 480 SE @ 840
4Gb OCz Platinum DDR3
2x 500Gb HD in Raid 0
DVDRW Drive
2x 120mm case fan
4x 140mm case fan
CoolerMaster V8 cooler
CoolerMaster Real Power 850w modular PSU
CM690 II case
Power meter was measuring draw from my base unit only, monitor etc were on different circuit.
Idle: 134W
GPU Load: 360W
GPU+CPU Load: 480-550W (550W was peak, but mostly stayed around the 500W mark).
In game: 404W peak
All tests involving GPU were roughly 60W less when the GPU is at stock.
Thought some of you may want to see this as there's been a lot of questions recently about power draw of 480s. The good news for me is that I can add a 2nd 480 in SLi on my current PSU.
i5 2500k @ 4.5ghz
DVDRW Drive
2x 120mm case fan
4x 140mm case fan
CM690 II case
Idle: 134W
GPU Load: 360W
In game: 404W peak
