seriously look at the 990FX range from ASrock. should be close to your budget and they offer everything you require.
you cannot judge a component, or anything for that matter, on price. just because something is more expensive does not make it better.
things to consider :
pci-e spacing
pci-e speeds in CF/SLI
SATA III ports
USB 3.0 Ports and Headers
Ram Slot & other Components positioning (for aftermarket coolers)
Chipset
CPU Support
ummm cant think of anything else.
ASRock 990FX Extreme 4
■Premium Gold Caps (2.5 x longer life time), 100%Japan-made high-quality Conductive Polymer Capacitors
■Supports AM3+ Processor, 8-Core CPU
■Supports Dual Channel DDR3 2100(OC)
■Supports AMD Quad CrossFireX™, 3-Way CrossFireX™ and CrossFireX™
■2 x Front USB 3.0, 2 x Rear USB 3.0, 8 x SATA3, 2 x IEEE 1394
■Dr. Debug, Power/Reset/Clear CMOS Switch with LED
■Supports XFast USB Technology, Graphical UEFI BIOS
■Supports On/Off Play Technology, Instant Boot, Instant Flash, APP Charger, SmartView, Turbo UCC
■7.1 CH HD Audio with Content Protection, supports THX TruStudio™
(not sure why the pic on their site looks like it has thermal paste all over the cpu socket
not sure when it is out though and im not sure if it will have SLI support.
EDIT : ok on the specs page on their site :
- 3 x PCI Express 2.0 x16 slots (PCIE2/PCIE4 @ x16 mode; PCIE5 @ x4 mode)
- 2 x PCI Express 2.0 x1 slots
- 2 x PCI slots
- Supports AMDTM Quad CrossFireX™ , 3-Way CrossFireX™ and CrossFireX™
- Supports NVIDIA® Quad SLI™ and SLI™
so think it will do sli too.
