I can see from the pictures linked what allows this to hover but what propels it forward?
Tilting the whole vehicle forward to push air backwards so you move forward?
You.. leaning forward at a guess Sonea!
EDIT - FFS lol, everyone answering at the same time!
Much like a helicopter has blades that can turn to push air back as well as down, this will just be done by moving your body weight forward i imagine
I imagine that distributing your weight towards the front would propel you forward? I.e. point the nose down so the fans push air at a downward/backward angle.
I see.
I see.
I may have had a few beers but I get the picture guys and am spotting a trend in posts here![]()
You missed the first one out although i'm guessing that's just because of the multiquote limit?
It's going to need some mad electronics and gps to keep that thing steady roll should be covered by the gyro effect, but pitch and height will need to be closely monitored and controlled. Perhaps gps for when you fancy going to the clouds, and lasers for when you want to follow roads. Probably gps to keep both rotors at the same height as each other too, or just a simple motion switch. Definitely doable.
brb, off to attach two desk fans to my bike
