AMD Catalyst 11.6 WHQL (8.861 May 24) - Download & Discussion
Just installed these, I hope they fix the light problems in the witcher 2 and pos increase performance slightly on ati 6970
Just tried them and it does indeed sort the lighting issue. TW2 is running super smooth in xfire for me know with lovely vsync on. :)
I have no xfire with these 11.6 drivers not even a xfire option in the CCC.
Running a 6990 + 6970 in trifire.
Tried the leaked version and now the ones on official site and get the same problem so gone back to 11.5 B
Not according to AMD, they always advise uninstalling previous drivers first.
Especially if you're using beta releases.
Then why do they allow their own software and steam to update the drivers?
There isn't even a warning message when you start the installation to uninstall previous drivers first.
What is improvement of CAP 5?
And should I install it for my 4870 x 2 (Dual GPU, not two 4870 cards):)
This is bad really bad for me, I'm currently in safe mode because this new driver update is causing my pc to restart soon as the windows loading logo has finished loading. Might as well revert back *sigh*
I hope all you people who are having issues are running your GPU at stock clocks to take that aspect out of the equation as different drivers can effect the GPU OC headroom.
