How do you control the Hoverbike?
•To lift off into a hover, one needs to increase the thrust via a throttle grip with the right hand - exactly the same as the throttle on a motorbike
•To fly forward a combination involving an increase in thrust and the deflection of air from the front control vanes (twisting the left handle grip) will tilt the total thrust vector forward resulting in an acceleration forwards (twist back to go backwards)
•To to make the bike roll (turn) left and right, all one needs to do is push the handle bars down on the side you wish to turn (handle bars work just like a bicycle, but with an extra axis so that they rotate up and down a little) - you could lean in the appropriate direction just like a motorbike, but this is proving to be not as sensitive as one would expect or like.
•Yaw (nose left or right) is via control vanes front and rear and actuated by turning the handle bars - just like a bike
