Best upgrade from 260GTX? £200 Budget
1 Apr 2010
Hi,
Im currently looking at purchasing a new graphics card and have a budget of about £200. What should I get? Please see PC spec below
q6600 @ 3.55 Ghz
Gigabyte Motherboard CF able
4GB Ram
260 GTX 216
80GB Intel SSD
500GB WD HDD
Regards,
astar0
Upgraded from my GTX260 216 back in December to a GTX470 and found that to be a massive upgrade. What resolution are you gaming at? At you budget a 6950 sounds perfect or a GTX480 for a bit more performance (bit noisier and hotter though).
If you can stretch a bit (or get one on sale) get a 480GTX. Probably best value for money at the moment, and you can get ones with ultra-quiet coolers. Make sure your PSU is powerful enough though.
Otherwise, 6950.
Gainward GeForce GTX 560Ti "Phantom" 1024MB £200
http://www.overclockers.co.uk/showproduct.php?prodid=GX-145-GW&groupid=701&catid=1914&subcat=
EVGA GeForce GTX 470 Superclocked with Backplate/Bracket 1280MB £200
http://www.overclockers.co.uk/showproduct.php?prodid=GX-127-EA&groupid=701&catid=1914&subcat=1810
OR
MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB £200
http://www.overclockers.co.uk/showproduct.php?prodid=GX-128-MS&groupid=701&catid=56&subcat=
If you can push to £220 ish there are even more options...;)
I dont mind stretching an extra £20-£30 if its worth it. I see i can get an 480 for that.
Is this a better option than the 6950?
Really a trade off. GTX 480 is more powerful and will overclock further. There are not guarantees that the 6950 will unlock to 6970. IMO better drivers from NVIDIA. The 480 is more power hungry and will run hotter and therefore louder. Might be worth checking out reviews of particular games you play and see how they fare against each other.
with my recent ATI issues i cant recommend them.
