Today Only, life is better in 3D especially at the price we have the LG W2363D 23" TRUE 120Hz 3D Widescreen LCD Monitor today. We have very limited units so snap it up when you can. The Intel Core i5-2500K 3.30GHz is the perfect sandy bridge solution which has a fantastic overclocking ability.
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor @ £154.98 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 3yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Only £154.98 inc VAT.
ORDER NOW
LG W2363D 23" TRUE 120Hz 3D Widescreen LCD Monitor - Black @ £159.98 inc VAT
Redefine standards with LG W63D, A full HD 3D monitor created for a new level of gaming experience. Its Full HD resolution comes complete with 120Hz refresh rate, allowing clear 3D picture quality by cross-minimization through 172Hz data processing. W63D series reproduces incredibly realistic 3D effect to stimulate your infinite imagination. Full HD 3D W2363D perfectly reproduces various Full HD 3D contents such as games, animation, and films without any loss and also supports vivid 2D picture quality that equals any 2D Full HD product. Real time 2D to 3D conversion When 3D contents are played, NVIDIA 3D Vision automatically senses the contents and converts to 3D mode so that 2D and 3D multimedia contents can both be enjoyed conveniently without requiring any complicated setting. 3ms response time The ultra-fast response time of 3ms reproduces crisp pictures without transient phenomena. You can play speed games and watch action movies that have fast motion and action without ghosting or shaky image. 120HZ refresh rate W2363 reproduces images at 120 frames per second to provide perfect reproduction of pure 120Hz next-generation fast motion pictures in 2D mode while displaying more vivid 3D pictures in the shutter glasses 3D system. G-mode As an exclusive feature of W63D series, G-mode provides an ideal user environment that enhance your game experience. 1.9 Crosstalk W2363 minimized crosstalk to 1.9 percent by supporting 172Hz image processing and maintaining a stable 120Hz screen as well as by supporting rapid image transition through dual gate feeding.
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 70000:1
- Brightness: 400cd/m²
- Response Time: 3ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Warranty: 3 Years On-Site
Only £159.98 inc VAT.
ORDER NOW
- Cores: 4
- Threads: 4
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
ORDER NOW
- VESA Compliant
ORDER NOW
