Powercolor 5850 xfire with Sapphire 5850 Extreme
On second though will my 620W Corsair HX be enough to handle a second 5850? I used a Wattage mains adapter that showed my PC using only 260W on load
Did you find out if your psu can handle xfire?
I want to borrow another 5850 to test but I'm unsure if my 600w can handle them
doesnt look like much in it though comparing the 5850 to a 6950 in x fire mode like i have the sapphire 5850 and was thinking of new m/b mem cpu for bf3 the back end o the year and getting a new card but may just get another 5850 and see what new cards are availible in a years time i have a seasonic 600w psu so should be okay there like. just my opinion cause the 5850 cards are bloody good bang for buck at the moment ???
as BF3 isnt out, no one really knows what will run it, so if you want and upgrade then go the cheapest (best value) option. which would be another 5850. these should atleast hold some value at the end of the year still, so if you decide to do a complete upgrade you will be able to sell on to help fund it.
