Just had this car over a long weekend for a trip to Cornwall and family wedding in Devon then back down to St Ives and popped over to Land End (horribly commercialised since I went as a young boy!), put 950 miles on the thing in 4 days
What a beast:
Engine is superb... for a diesel. Its not the last word in refined, mainly due to the noise but its admirably dampened within the cabin and the only real intrustion is cold start. Idle still has that characteristic cabin resonance that even more marked as my usual car is absolutley silent at stop.
Engine is super flexible and I'm keen to try the engine with the 8HP70 box when that becomes standard fit, Jaguar claim 500Nm is available from idle within 500ms. The progressive power is then turbine smooth although kick down can be a little slow at times, but then this is a XJ not XK. To prepare for an overtake a tap or two on the downshift is all you might need to minimise time exposed to danger.
The
suspension is a typical coil spring setup at the front but with air suspension at the rear with active control on the damping rates to control the body. This amongst several other factor (ie ally body) really masks the vehicles weight and also its feeling of size. For 19" wheels the ride is exceptional without being too wafty, slow speed the ride can be a little figety and normal urban roundabout to roundabout could feel a little nervous in normal mode, I found dynamic setting far better in that regard, but all round its nothing short of impressive.
I covered the usual motorway and A roads etc right down to the streets of St Ives! What really struck me was the dual nature of the car, you could be cruising down the motorway at 85 listening to music with quiet conversation or in B road blast mode gunning past Honda Jazzs and Tractors with V6 growl and then arather intoxicating growl resonating through when you changed gear at around 3k. Then the car was more than happy to provide a decent amount of weighted feedback with excellent roll control as you satisfying link any number of corners up across a range of speeds with the reassurance a truely impressive set of brakes in case you get too carried away. This was proper car stuff, particularly for what is essentially a base model - the SuperSport must be epic
The dual panoramic roof was great aswell, each panel has a electric blind with the front larger panel having tilt and partial slide and the interior really needs no introduction, Jaguar has a deserving reputation for offering a cabin with character and ambience and this delivered.
Little thing like the auto raising steering column when you opened the door, the rotary selector rising and keyless system to start the car and then drive off without having to disable the handbrake all set the scene for just how effortless this car is to drive and then do serious miles in. It was a fantastic way to learn more about the car I work on and discover its real world attributes and charm.
I may be tempted to come along to the RR day in it aswell
Oh and last week I drove an XK 5.0 NA - 385 bhp! Excellent car without being too bonkers like the XKR! and the pleasure of a 2.2 fully specced up Range Rover Evoque Coupe - VERY impressive.
Ignore the fact you can see the PCB in the headlight
