Mine has only just come back on. Couldn't connect at all since 4:30. The DSL light on the Openreach modem would flash green, then go out, then flash green etc.
The BB light on the HH would stay a solid orange.
EDIT: And just went down again.
Boring!
My connection is dropping daily now. Still requiring 5-7 turn off and ons of the equipemt untill stable.
Max speeds have totally dropped to 22mbps from 37mbps....
How are you not getting the message that you should keep the hardware running without restarting it?![]()
what is your IP profile on BT speedtest website.
Internet has been turned off last 2 hours.
Cant get it to stay up for more than 5 minuites.
Either Broadband light on Hub goes down or dsl light on modem turns off.
Only way to get either back up is to turn it off and on again.
About dropping speeds from cabinet, I would just get BT to reset it.
I have a major issue, which has basically deteriorated to the point I have to leave the hub/modem off now becuase there isnt any point having it on!
Whats your IP Profile? - http://speedtester.bt.com/
Have you got BT coming out?
Possible crosstalk?
What happens if you wait for it, dont turn off/unplug everything?
Sounds like a dodgy modem. Call BT, tell them that the modem won't connect. They'll ask you to unplug your landline and will run a line test and call you back on an alternate number. Then they'll arrange an engineer to come out and replace your modem.
I had the same problem.
