Now i have looked on the OC site and cant see any radeon cards above a 5770 & 6450 that are passively cooled. Are they any higher performance cards than these that are passively cooled that would be decent for 1080p gaming on my media center PC??
How do i know which ati cards are classed as slient though??
You could try something like one theseHow do i know which ati cards are classed as slient though??
You could get a card eg 6850 and fit an aftermarket cooler to it.
What exactly is your budget?
My budget...no more than £100 really, as its only for the media centre PC so wont be massively used, ill only be gaming at 1080p on it, so just for PC gaming where id like to sit down on the sofa and play with a pad, so not afrer anything top of the range just something that will play majority of games well
i suggest getting a decent older card, and fitting an aftermarket passive cooler to it
i got a 4870 and ive been playing crysis 2 at 1080p no problem and that was a lot less than £100![]()
So would a 5570 1GB be upto the task...these ATI model's make my head hurt
http://www.overclockers.co.uk/showproduct.php?prodid=GX-123-HT&tool=3
I would say not really. Go for the 5830. My 5850 was literally silent unless it was at 100% which it never reached unless I did it manually through afterburner.
Even at 100% I could only just hear it.
OP, there's a certain place doing 5750 1GB cards for £48 new.
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=56&subid=1711
All pretty much absolutely silent
Marvin, the 5830 is louder? I thought it was a downclocked 5850 with less cores/shaders?
Panyan, I was recommending the 5839 without an aftermarket cooler in it as IMO it doesn't need one as it's already near silent.
Would this place be the same name as what happened to the sun yesterday at approx 21:30 time??
