Logitech G27 extension for gear stick
2 May 2004
I'm about to buy a Logitech G27. Luckily I was able to test my brother's G27 on my desk before going ahead with anything.
The cable from the gear stick to the wheel could do with being a bit longer so I can router it down behind my desk and run it alongside the other cables properly.
Can this cable be extended? It's almost like a smaller VGA port.
Thanks.
That's sort-of because you're not asking a straight question.
RS-232 is a signalling standard, and DB9 is a connector standard. Most cables that are intended to carry RS-232 signals, have DB9 connectors -- but some RS-232 cables have different connectors, and some cables for other signals have DB9 connectors.
Thats from another site I didn't get much but maybe you will understand
