Cases and GTX 480 SLI help!
19 Apr 2011
Hey guys, long time reader first time poster :)
Recently I bought a PC and bundled it together - and foolishly (this was a first build) I chose a case that wasn't really up for the job.
Specs:
GTX 480 SLI
Intel 2500k with Coolmaster Hyper 212 Plus
I am returning the motherboard I'm using due to the Intel Chipset ordeal, and so I'm going to A) need a new motherboard
and B) need a new case
At the moment, I'm using a cheap £30 case that quite frankly - is causing more harm than good.
Temperatures -at idle- (with a very low ambient temperature) are bad - worse when gaming (90-100 constant+)
My idea is to maximise the spacing between the two graphics cards (for temperature reasons) and also because I plan on fitting the Zalman after market coolers:(at some point)
"http://www.overclockers.co.uk/showproduct.php?prodid=HS-050-ZA"
Now, these make the cards 3-slot so I'm worried about spacing and that causing problems, hence why I'm looking at motherboards and cases. Here's my dilemma!:
I'm looking at the Z68 boards (though P67 would do, would it not?) with large spacing between the PCIe16x slots. I've found two that are within my price range ( around £150):
http://www.overclockers.co.uk/showproduct.php?prodid=MB-051-AK
http://www.overclockers.co.uk/showproduct.php?prodid=MB-457-AS
I'm currently taking a bit more liking to the asus, but that's simply because I know the brand. A little worry of mine is this tiny socket that may become blocked: can anyone explain what this input is for?
My main worry however is this:
I'm looking at the RV02 or RV02-E case at the moment
(http://www.overclockers.co.uk/showproduct.php?prodid=CA-065-SV)
(http://www.overclockers.co.uk/showproduct.php?prodid=CA-073-SV)
, and one little worry is this: I've made a picture to show the problem clearly, as I can't really explain it easily:
Whilst I won't be fitting the Zalman immediately, and hope I won't need to if it's a lot quieter and the temperatures are down - I would rather be happy to know that it's an option that I can fit them.
Does anyone have this case, and know whether the HDD/Disk Drives will collide? I can do without a HDD (I use Steam for all my games anyway) but if the HDD collides, I may have a problem.
Can anyone be of assistance? Thank you! :)
The images I've made are mock ups, they might be completely wrong (ie the motherboard may not be correctly aligned, nor may the graphics cards, but should show what I mean)
:confused:
The third PCI-E slot on both those motherboards runs at a lower speed than the top slot, if you use the two top slots you will still have a decent enough gap between the cards.
Just use the standard coolers that expel hot air out the back of the card instead of dumping it in the case.
Yeah, the bottom slot runs at PCIe 2.0 x4. This will actually be noticeably slower, unlike the top two which will run at x8 (1-2% difference from x16).
Agree with Stulid, just get a (or 2) card with the reference cooler which dumps heat out, rather than an aftermarket one which dumps it in, problem solved
Also x4 only has 4% performance drop, not really "that" noticable
Ah right,so sticking with the reference cooler would be better? I suppose that makes sense with the way the case is intended to work. If the loss is only 4% - would that be worth the difference in spacing? Or is that small extra gap not worth the loss. 4% seems reasonably small.
Think I'll drop cooler replacement idea anyway - I wasn't keen with the idea of loosing warranty from the beginning (darn it Asus!)
the stock cooler is fine, spending £70 on a pair of those Zalman coolers could be spent else where.
