Seems to be Intel C-State under CPU Features, at first this kept somehow being disabled automagically in the BIOS.
Enable it and you should notice the multiplier lowering down to 16 when idle.
I also have EIST enabled.
I 2nd that.
As mentioned above did try this but it did not take.If you just want 4.2GHz at less than 1.3V, try out what mikeo did.
Post #14
I'd also recommend a few hours of LinX (All Memory), I tend to use short bursts of Prime95 and LinX to see if it is stable. LinX first, 30 minutes then Prime95 blend 1 hour. If it passes both go for longer stretches. What I've found is certain overclocks fail on LinX quickly or Prime95 quickly, but they seem to pick up different issues. Hence why short bursts of one after another is a good indicator that the clock is stable. No point doing 8 hours of Prime95 if LinX makes it fail after 30 minutes.
I'd suggest being quite careful leaving things like vCore on Auto, you need to keep an eye on it at higher clocks as it tends to push things up to silly levels.
There is also no real need to change much more than Muliplier, Vcore and CPU I/O (to bring the memory speed up). Turbo, EIST, C1E can all be left to their default settings for regular overclocks (sub 4.8GHz) in my experience.
The strange thing is that one core 0 has temps 15 - 18 degrees cooler than the other three! Anyone know if that's normal?
That's a bit of a steep difference. Are you sure the cooler is mounted properly? Might be worth taking it off, cleaning it, and reapplying the thermal paste.
Right....
Easiest way to OC on this board (mines a P67A-GD65) if you are not looking for the absolute MAX but just a decent stable OC.
Please note that this is only my personal opinion but I do after all have a similar MSI board.
Forget about changing the CPU ratio and fiddling with the voltages (or anything else come to that).
Load default safe settings, making sure you set anything that you definately need (like AHCI for the SATA ports).
Go to the OC setting menu, scroll down to the bottom and select CPU Features. Then change the turbo settings on the 4 cores from 37/36/35/34 (assuming here they will be set as per my board) to say 42/42/42/42. Leave voltages and EVERYTHING ELSE unchanged. Save your changes and re-boot.
JOB DONE.
What you will have now is a system that throttles back the volts/ multiplier when not under load but ramps up to 4.2 GHz under load.
Obviously run IBT and Prime95 to test stability.
I found exactly what you did. If you change the CPU ratio in the top level OC menu. It applies this OC "all the time" and the CPU voltage is around 1.368v. A bit on the high side for this sort of OC .
Doing it as I suggest. Gives me a stable system with a decent OC. Interestingly, CPU voltages never go above 1.288V (much better) and temps in Prime95 after 6 hours are only around the 60C level. Obviously you need a half decent cooler. Mines the Gelid in my sig. (pretty popular at the moment).
In my opinion, I don't think you need to do it the "traditional way" (IE. fiddle with loads of different settings) unless you want to hit really high OC's.
Only my opinion folks. But it works for me.
Interesting way of doing it. I tried using OC Genie but my voltages went up to 1.36-1.38V @ 4.2GHz which seems kinda of high (never OC'd before, voltages before were 1.00-1.23V). Think I'll give your method a try and see what happens. Out of curiosity, why does turbo boost the cores to different levels by default?
(and reduces the multiplier to x16 on idle!), going to run Prime95 for an hour and see what happens. If it doesn't cause problems that's definitely a very easy way to OC with reasonable settings.
Well it boots(and reduces the multiplier to x16 on idle!), going to run Prime95 for an hour and see what happens. If it doesn't cause problems that's definitely a very easy way to OC with reasonable settings.
VCORE so far hasn't gone above 1.288V as you said, CPU core temps are already at 50-56C though![]()
Thermal Paste is Thermalright Chill Factor II in the middle of sandybridge cpu with a pea sized.
2 of the cores did less tests in prime95 though, is that normal? (core0 - 77 / core1 - 74 / core2 - 67 / core 3 - 77 tests)
Mine is @ 1.27vcore for 4.2GHz and temp read out 52/56/57/53 with Corsair H50 (2 x vipers fan as a push pull but fans never spin more than 1250rpm. Prime blend for 8 hours. Much better than bloomfield i7 920 @ 4.2GHz. Slightly improvement on sandybridge. Cinebench R11.5 score 8.08 points for i7 2600k while 6.94 points for i7 920. Big differentThermal Paste is Thermalright Chill Factor II in the middle of sandybridge cpu with a pea sized.
Today after prime blend stable after 8 hours of 4.60GHz @ 1.36vcore read out core temp of 57/61/62/58 pretty good indeed. I am now settle with 4.6 rather than 4.2. Cinebench R11.5 score 9.27 points.![]()
Looking good.
Out of interest, as I see you are running XMS3 memory. What speed and voltage are you running it at? You will know doubt be aware that there is a lot of discussion about memory voltage on Sandy Bridge.
I'm running 8GB of XMS3, I just enabled XMP for mine so I think its running at 1600MHz/1.65V.
Did it set the correct timings? The XMP on my board / BIOS choose 9/10/10/25, rather than what it should have been (IE. 9/9/9/24). Even though CPU-z shows the correct timings for the XMP profile. Strange it is! So I just set the speed / timings manually. By all accounts XMS3 is capable of running at 1600 MHz at 1.5v, or even lower if you are lucky. Mine set at 1.521 passes an hour of 4 occurance of Memtest running. Though a lot of folks say memory running at 1.65v should be fine. It's just the word "fine" that got me thinking. Hence why I tried it at a lower voltage.
