this is what ive come up with. with a few money saving parts ive squeezed a GTX570 twin frozr III into the budget. you wont need to make any changes if you plan on including a second GTX570
YOUR BASKET
1 x MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card £269.99
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £156.98
1 x Asrock Z68 Extreme4 Intel Z68 (Socket 1155) DDR3 Motherboard £144.98
1 x XFX 850W Black Edition Modular Power Supply £118.99
1 x Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive £91.99
1 x Cooler Master CM-690 II Lite Dominator Case - Black £59.99
1 x Thermalright Silver Arrow CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA775/AM2/AM3) £50.99
1 x Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) £39.98
1 x Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) £34.99
1 x LiteOn IHAS124-19 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £1,000.88 (includes shipping : £12.50).
the PSU is more than capable of running two of these cards in SLI. i believe, but i am not sure, that the 750W XFX unit is powerful enough to run two 570's in SLI, so i personally cannot recommend downsizing. however, if someone can show me how much power these cards use in SLI then you may find the 750W one is enough. its definitely a good quality PSU as its a rebranded seasonic, which is what corsair PSU's are![]()
This is better than what I suggested if you don't need a blu-ray player![]()
You could up the PSU in mine if you take out the windowed side panel, to allow for future CF/SLI
