Two great Monday morning deals. Introducing the new AMD Phenom II X4 Quad Core 850 "95W Edition" 3.30GHz at a great price of £77.99 inc VAT. Another sweet deal Zalman CNPS10X Extreme CPU Cooler which is a fantastic cooler which is perfect for overclocking at a great price of £37.98 inc. VAT.
AMD Phenom II X4 Quad Core 850 "95W Edition" 3.30GHz (Socket AM3) - Retail @ £77.99 inc VAT
At home or at play, AMD Phenom II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Quad Core Technology
- 3.30GHz Clock Speed
- AM3 Socket
- 2MB L2 cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Only £77.99 inc VAT.
ORDER NOW
Zalman CNPS10X Extreme CPU Cooler (Socket 754/939/940/AM2/775/1155/1156/1366) @ £37.98 inc VAT
At the heart of its design, the CNPS10X consists of an optimally designed stack of black pearl nickel-plated aluminium fins which disperse heat away from the processor via five heatpipes. The high-capacity ultra quiet 120mm fan then quickly cools the fins, condensing the liquid inside the sealed heatpipes so that the process can be continually repeated. The CNPS10X provides fast and effective cooling for processors with a thermal output of up to a massive 340 watts of heat! The CNPS10X is compatible with Intel LGA1156, 1366, 775 and AMD AM3, AM2+, AM2, 754, 939 and 940. All single, dual and quad core processors are supported.
- Socket Type: AMD 754 / 939 / 940 / AM2 / Intel LGA775 / LGA1366 / LGA1156 / LGA1155
- Dimensions: 94mm x 100mm x 160.0mm
- Fan Dimensions: 120mm x 120mm
- Fan Connector: 4-Pin (PWM)
- Fan Speed: 1000 - 2150 RPM
- Noise Level: 20.0 - 39.0 dB
Only £37.98 inc VAT.
ORDER NOW
- AM3 Socket
- 2MB L2 cache
- 64-Bit Technology
- 3 Year Warranty
ORDER NOW
ORDER NOW
