Win 7 Folder Views
29 Sep 2004
Wilt of the Shire
My views keep changing in explorer (Win 7 x64) to the details setting. I like to view them with the list setting, they change even when I apply the settings to all folders. This used to happen ages ago and it's getting a bit annoying now having to change the settings every time I go into explorer. Is there an add on or something that will stop these changes?
This happens randomly to my Recycle Bin. Sometimes it even goes back to how i like it (Detailed) without me doing anything...! But never had it with general folders...
I have no idea why.... lol
Have a similar problem where foders won't remember individual settings. Have you mapped your Documents folder to a 2nd drive?
This problem is something I have experienced since XP and I have always had a separate documents drive where I plant my default documents folder.
Will try the reg fix!
Let us know how the reg fix goes. :)
I dont have an issue with other folders, (Least i dont think so/haven't noticed it) just always seems to be my bin..... Random.
It will take a long time to confirm, I always cleared the bagsMRU entries in the registry to temp fix it for a few months but it always came back after a while with random folders forgetting their views. Right now only certain folders always forget their views after a day.
