[TW]Fox;19400641 said:Seriously?
yes
[TW]Fox;19400764 said:Just... there are no words.
Surely the right wheel drive varies from car to car.
Just watched the lap full screen at 720p on youtube, and its clear why the time was so good. He was being quite a hero on some of those corners, leaving absolutely no room for error, especially the last few corners, jesus. He was breaking far too late on some of the corners though, and on some, even braking through them. He was going way too hot through some, which makes me think the lap could have been even quicker. I could see his frustration with not being able to get the back end out at all when he wanted it too.
[TW]Fox;19416090 said:He clearly needs to call on your amazing skills for the next run, as you obviously know more about how to drive the 'Ring than he does.
Judging by the start and finish points that lap (assuming you mean the one posted by Spaz earlier) looks like a "warm up". The R26.R lap was a rolling start (which started and finished at the same point) whereas this one wasn't.
One can only assume the actual lap was even faster / cleaner.
A 'full lap' is bending the truth ever so slightly (although an accepted measurement and how everyone times their full laps) as the start/finish markers are at the point where the nordschleife joins with the gp circuit, so arent the same line and are a few metres apart from each other, so in this case they just happened to start the lap at the other side of the barrier before the first corner, hence the ability to do a flying lap instantly, like in this case, rather than an additional out/in lap.
