Don't miss out on today's best deals for Today Only. Limited units at a vastly reduced price. Hurry!
ZOTAC GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card @ £143.99 inc VAT
Next-generation gaming has arrived. Nvidia GeForce GTX 470 gives your games an adrenaline shot with screaming fast performance and futuristic, visually stunning graphics. Experience heart pounding,
cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jaw dropping
stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 470: pure adrenaline meets visual bliss.
- Core Clock: 607MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3348MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 448
- Shader Clock: 1215MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 5 Years
Only £143.99 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) @ £24.98 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
Only £24.98 inc VAT.
ORDER NOW
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 5 Years
ORDER NOW
- 1333MHz DDR3
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
ORDER NOW
for the £££
