I think that is a bit misleading against a DSLR. Image Quality on the Nex is as good as any entry level DSLR as are the controls available, I use full manual controls or either P or S mode with no problems, It took a few weeks of constant use to be used to the differences against other cameras but that's true of all different makes and models as well. Now additional lens will improve the DSLR but it still costs to get them and as stated the Nex is getting better over the next 18 months.
IAuto and Scene modes are excellent and the firmware update introduces new things like single colour shooting, peaking for manual focusing. My wife has no issue with using iAuto as well as panaoramic mode.
It shoots raw, Jpeg or raw+Jpeg as well so allows full processing of raw files as well.
While there are no direct dials to turn it operates exaxctly like an SLR. From having a histogram on the live view to all relevant information needed on display.
The Macro is due in October and there is still no confimration on any of the other lens.
I have the ultra wide adapter which turns the 16mm in to a 12mm Ultra Wide and it's a great little item, fisheye to follow.
Really I would go try them out in Jessops or any other retailer to get a feel before deciding as sometimes it's how it feels rather to handle that can be a deciding factor. I have really small hands and found some of the DSLR's much too big to get comfy with hence my choice.
