Phenom ii x4 840 not OC
8 May 2011
right i have the above proccessor xms3 ram sythe samarai cooler and gigabye GA-M68T-s2 and i cant get the fsb above 204 without it booting in safe mode and asking to reset cpu frequency
HELP PLEASE
While you're waiting please check the model of the motherboard as there isn't a GA-M68T-S2.
Is it the GA-M68MT-S2?
What speed are you running the XMS3 at?
There you go, a free bump while asking relevant questions ;)
1333MHz then.
You could try reducing the memory multiplier to 5.33 to start of with.
That way you'll know it's not the RAM if the overclock fails.
And BTW, you have 1 line too many in your sig.
Is my sig better now and cheers will try the mem multiplier tommoriw
Sig. looks fine :D
When you increase the FSB you increase the speed of the RAM as well as the processor.
By reducing the RAM multiplier you know you're not overclocking the RAM too far and can rule that out if the overclock fails.
