My New PC, Possibly.
Any of them, the FLEX card is only good if you want a Eyefinity setup, otherwise there are cheaper 6950 cards.
OR THIS.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-272-SP
Sapphire ATI Radeon HD 6950 FLEX 2048MB GDDR5 PCI-Express Graphics Card with upto 5 Monitor Support
Are you gonna use 5 monitors? If not you might as well the extra towards a better card unless that's your limit.
OR THIS.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-127-MS
MSI ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card
I would choose this over the Asus just because it's £15 cheaper for pretty much the same speed, don't know how the coolers differ though.
Do'nt know one card from another, just want a good card with crossfire and my budget will be (when i've saved it) £200 to £250 no more if i can avoid it. Advice please, in other words the best i can get for the least money. I'm only like everyone else in that respect. Just would like to have a card that will let me play some top end games, but like i've already said, i'm not a full time gamer.
No i won't ever be using 5 monitors, i would just like a good card to play on a large single hi def monitor.
Can be turned into a 6970 with a simple bios flash, free performance.
If i was to go for this card at some point, does it mean that if i bought another, again later on, i would be able to use them in crossfire mode? and if yes, do i just need a crossfire bridge cable? Would 2 cards in crossfire give a lot better performance than 1 really good card?
how big is the monitor going to be, max resolution?
Now you got me. I was thinking something around 27inch to 30inch. Has to resolution, i have'nt got a clue until i actually see something i fancy. A bit vague i know, but i have'nt got that far yet. It's just something for the future. My present monitor is a 21inch Samsung Syncmaster, and i have to say, touch wood, it's never given me a moments trouble.
So something like,
http://www.xbitlabs.com/articles/monitors/display/dell-eips-roundup_8.html#sect0
http://www.xbitlabs.com/articles/monitors/display/samsung-sa850.html
How about something like this.
http://www.overclockers.co.uk/showproduct.php?prodid=MO-011-HO&tool=3
Hazro HZ27WC 8-Bit 27" LED Widescreen Professional Glass Monitor - Black [HZ27WC] £399.98 inc VAT
with this perhaps.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-192-XF&tool=3
XFX ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card [HD-695A-CNFC] £199.99 inc VAT
Take me a bit of hard saving up but gives me something to aim for, if they work together ok that is, pc, display & graphics. If not i can always go for a good 24inch monitor for less money.
