So, today I had a bit of a nightmare. Browsing as usual and I nocked over a full glass of water. A whole load of it went straight into my keyboard (there was a puddle under the keys), and the rest of it went over the edge of my desk, and into the top vent of my PC. Outragously bad luck.
Anyway, as soon as this happend, some fans started spinning up (think it was the graphics card). I turned the PC off as soon as I could.
Upon further inspection, I saw that the sound card was soaked, and the graphics card which was just below it, was also quite wet. There were also many droplets of water all over the motherboard and the whole inside of the case. I assume this is from the water hitting the top fan and being sprayed all over the place.
To make matters worse, the water first went through a dirty dust filter, so all of my nice white fans and new hardware are now covered in dirty water. Great.
I have taken some components out and dried everything best I could. How long would you suggest I leave it before attempting to test things? I am thinking 2 full days should be alright, but I'm not sure.
Has anyone ever had a disaster like this before? what are the chances of things still working?
Thanks!
Thanks!
