Caporegime
- 21 Nov 2005
- Cornwall
You don't need to use much weight, you just need to keep a straight back, so it won't really effect your anus
I'll probably find a way to get rectal prolapse within a week!
I weigh 14kg and I'm not technically overweight, I have a good BMI.
I drink occasionally, probably once a fortnight at most. I'm driver most of the time and live out in the sticks so i don't really do alcohol on anything more than once fortnightly and that's being generous.
I'd rather just aim at my core. Running seems to be doing what i want for my legs and the core is the only part of my body that isn't in good shape and i've been at overall exercises for two years seeing no improvement and i'm getting kinda sick of it tbh..
14 stone im guessing, so your in a good place for your height. maybe aim to get down to 13 and a half stone as a ideal weight. but only if you have packed on some muscles around your core and upper body.
ignore BMI its hairy gonads to be honest.
if you have been at this for two years sounds like you need a change, hence the overall work out route.
even if you just do squats/deadlifts/benchpress it may just give your body enough of a kick up the backside to change a bit more. you dont have to go heavy on them, just enough to get a good sweat on and improve your strength which will aid in your running.
maybe go over your diet product by product to make sure you aint eating something thats loaded with rubish and you just didnt notice it.
other than that start lifting a bit, im sure if you hit google you could find a middle disntance runners routine someplace.
also can i come back to my original question - is it more beneficial to do my workout THEN go for a run or start with a run THEN do my workout?
I'd place less importance on that tbh.
IMHO GAC hit it right, you need to shock your body into responding, after basically spending 2 years doing what you're comfortable with.
Squats and basic compound exercises will help your core no end. Done right, you don't always need heavy weights.
If you can set yourself a decent routine that shocks....i'll be surprised if you have the energy to run afterwards.
Don't worry, consider giving running a miss for a week or so, whilst you get into your new resistance routine. It WILL drain you and the upside is your body will burn more calories at rest from such a routine.
Warm up sure, but don't be too fussed about your 20 min run afterwards. Not yet at least.
By all means look on youtube, make a note of the exercises (and advice) that look ok (not dangerous) and try them. If they work, great. If they don't, learn from it and pick one that will/does.
Don't be in a great hurry, cos if you go nuts and experience DOMS so bad that you can't even feed yourself properly, it may put you off, lol.
Delayed onset muscle soreness
what a pointless combination of ASCII characters this post it - if you have nothing to add, then you add nothing.
I've tried to not post in this thread as I'd be very tempted to write an epic but posting that link pushed me over the edgehow about this routine?? If it's sufficient to tire me out, surely it'll procure some results?
And er, what is DOMS??
Harsh?what a pointless combination of ASCII characters this post it - if you have nothing to add, then you add nothing.
