** NVIDIA GTX 460 OC 1GB GDDR5 NOW ONLY £109.99 Inc. VAT **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Bringing prices down further we have two storming deals from MSI in the form of GTX 460's with prices starting from just £109.99 inc. VAT. Now considering the last of the cheap GTX 480's are now gone and GTX 560's are circa £140 which are just an overclocked GTX 460, makes these an absolute bargain. Check them out:-
OcUK GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card @ £109.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 725MHz
- Memory: 1024MB GDDR5
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1450MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.3a
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was [£119.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics Card @ £127.99 inc VAT
The MSI N460GTX Hawk is the world's first graphics card to support voltage adjustment of the GPU, Memory and PLL making speeds, previously though of as impossible, easy to reach!
- Twin Frozr II Thermal Design 18 Degrees Celsuis Cooler and 8.1 dB Quieter!!-- Dual 8CM PWM Fans : Air flow from dual fans can cool down GPU/Memory/Power Module at once.
- Four heat pipes with SuperPipe Technology
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.
- 7+1 Phase PWM Design
- Higher current to GPU Powerv
- Higher overclocking capability
- Better stability in peak load
- Hi-C Cap provides more precise GPU voltage
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement
- All Solid CAP for longer lifespan
- APS (Active Phase Switch) helps save power usage by controlling PWM automatically.
- V-Check Points allow users to read voltage directly by multi-meter.
- Core Speed: 780MHz (Beyond 1000MHz possible but not guaranteed)
- Memory Speed: 1024MB GDDR5 3600MHz
- Shader Speed: 1560MHz (Upto 2000MHz possible but not guaranteed)
- Memory Type: GDDR5
- Memory Size(MB): 1024
- Memory Interface: 256 bits
- The world’s first graphics card supports voltage adjustment of GPU, Memory, and PLL.
- 7+1 Phase PWM design provides extra 30A current output power to GPU for better overclocking power capability.
- Hi-C Cap provides more precise GPU voltage.
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.
- All Solid CAP for longer lifespan.
- Reduces power consumption by switching of power phases dynamically when not in use (active phase switching)
- Support Over Voltage function of GPU, PLL and Memory
- Support advanced fan speed control.
- Support burn-in stability test.
- Support PhysX technology effects for realist physics effect.
- Support 3DVision Surround technology to provide 3 monitor output simultaneously and real 3D image experience
Was [£139.99] Inc. VAT
Only £127.99 inc VAT.
ORDER NOW
they are some really nice deals. makes them nice and competitive against the HD5850 now.
i was also preparing to write a small essay on every teeny tiny difference between the 460 and 560, but apart from the name, and the standard clock speeds, theres sod all difference, which makes it a fantastic deal
Agreed the GTX 560 is like the GT 440, they are basically just cards re-released with higher clock speeds.
Therefor this pricing makes the GTX 460 a bargain and as 5850 becomes harder to get hold off this deal will just get sweeter and sweeter. :)
after a long discussion (argument over a spec :p) in a thread, i have finally found out the difference between the GTX460 and GTX560 (other than clock speed:
the GTX460 uses the GF104 core architecture, whereas the GTX 560 uses the GF114 core architecture, which gives it a bit of a boost in performance per clock cycle
the 460's are still a great deal though
Cheers OCUK. Ordered the 460GTX Hawk on Saturday and it was delivered all the way up to a cold, cloudy Scotland early Monday afternoon. Now installed and running 42C cooler than my old rapidly expiring X1900XT.
This card is running with Win 7 (pushed the experience up to 7.2 from 5.5) and OpenSuse Linux. It's at stock at the moment, but will be boosted in the near future.
Once again, thanks for the great service.
