TODAY ONLY DEALS - 24/06/2011 - MEMORY & HEADSET DEAL!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Two cracking deals on TODAY ONLY:-
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) @ £23.99 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
Was [£29.99] Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Sennheiser PC 360 Gaming Headset @ £126.98 inc VAT
Developed with the top eSport team mTw, the PC 360 is a new flagship for pro gaming. It has an open design that makes sure you keep a cool head – and delivers a natural listening experience so you can stay in touch with your surroundings. Thanks to the ultracomfortable ear cups, pro microphone and quick-access controls, it’s also the only headset you’ll ever
need for music, videos and skyping.
Professional gaming with a cool head - the open design lets air in and delivers a natural listening experience;Sennheiser sound – excellent hi-fi sound and acoustics from your games, music, movies and internet calls;Noise canceling clarity – the microphone reduces ambient noise for crystal-clear conversations;All-in-one headset – when you want to enjoy movies or music, just move the microphone out of your way;Practical microphone mute – automatically mute the microphone by raising the boom.
- Cable length: 3m / 9.8ft
- Connector sockets: 2 x 3.5mm for desktop/laptop
- Weight: 300g
Frequency response:15–28,000Hz
- Sound pressure level: 112dB
- Microphone:
Frequency response: 50–16,000Hz
- Pick-up pattern: Noise canceling
Sensitivity: -38dBV/PA
Was [£135.99] Inc. VAT
Only £126.98 inc VAT.
ORDER NOW
Yeah fair point! :)
For next Friday may I suggest an i5 2500k at 145 quid and corsair sp2500's for 185? ;)
plus you'l need to get rid of your Ocz memory as you said they were pulling out of the market for RAM .. hence the lower lower lower prices :)
