Seeing as this is a fairly regular check, usually after every ride with a clean fortnightly? (is this correct?) I guess I should probably get some of the correct kit, cleaners, lubes, brushes etc.
My instructor had a chain oiler and I've noticed a few companies make them.
What are your thoughts? Are they worth the initial outlay? As I'll only be riding at weekends and during the summer I'm not going to be covering many miles and so I think it's probably over kill and should just stick to the manual method.
Is it just common sense as to the frequency of cleaning, if it looks dirty and is covered in muck then give it a good going over? I've been told and read that after a ride when the chain is warm is the best time as it will soak in better. I guess it's also a good idea to avoid getting the chain & sprockets particularly wet when washing?
I think the front sprocket is covered by a casing that I can remove but haven't had chance to look yet. Is it necessary to spray the front sprocket or will spraying the chain and turning the rear wheel be sufficient?
Any other tips are welcome
BennyC
BennyC
just make sure you use a decent anti corrosion like ACF-50 after you have washed metal bits, and lube the chain.
I have to do a tiny patch then move the bike forward, rince & repeat until you are Totally ****** off.
