- 22 Jun 2011
Hello - I have a 2001 318i.
I am going to be abroad for 5 months.
My plan was just to inflate the tyres up to around 45psi and leave it there. I hear mixed things about disconnecting the battery (some say the car can manage its power itself and so don't disconnect or you have to reset the radio) whilst others say it will be flat etc.
Engine - some say to tell my parents to start it and run it from time to time whilst others say that starting the engine for a short period will do more harm than good? So is the solution to just tell them if they're going to get it out to move it around to do that but then to leave the engine on for at least 1 hr afterwards? But then I've heard idling for long periods is bad too! The other option is just to leave it completely alone!
Fuel - some say brim it to stop condensation others say leave it empty to stop fuel bug.
Any other advice?
Thanks!
Stu
Any other advice?
Thanks!
Stu
