am i right in thinking that the ivy bridge cpu's will be having quad channel ddr memory, as opposed to dual channel on current sb's, which in itself should increase performance over current sandybridge cpu's
No, the Socket 2011 Sandy Bridge-E chips will be quad channel.
Ivy Bridge will use the same Socket 1155 as the current Sandy Bridge chips and be compatible with existing motherboards.
BD mobo will not be PCI ex 3?
Basically support for next gen standards?
It looks like to me x79 is what Im waiting for.
Will have all the upgrade paths available, particulalry PCI Ex3.
Current SB with its PCI Ex 2 and 8x 8x lanes, is not appealing.
Taken from here:
"PCIe 2.0 delivers 5 GT/s, but employs an 8b/10b encoding scheme which results in a 20 percent ((10-8)/10) overhead on the raw bit rate. PCIe 3.0 removes the requirement for 8b/10b encoding and instead uses a technique called "scrambling" in which "a known binary polynomial is applied to a data stream in a feedback topology. Because the scrambling polynomial is known, the data can be recovered by running it through a feedback topology using the inverse polynomial"[17] and also uses a 128b/130b ((130-128)/130)encoding scheme, reducing the overhead to approximately 1.5%, as opposed to the 20% overhead of 8b/10b encoding used by PCIe 2.0. PCIe 3.0's 8 GT/s bit rate effectively delivers double PCIe 2.0 bandwidth."
This isnt the exact article I saw, but they reckon that due to less overhead, even PCI EX2 GPU's will see increased performance in a PCI Ex 3 slot.
Would be nice if true.
, would be dissapointing)So what one is better, sorry to sound dumb?
Yeah it seems that Ivy Bridge will use the same socket but not be compatible with existing motherboards (which seems really dumb, mistakes are gonna happen - why not just add or remove a pin like AMD did in the Socket 939 days?).
i dont think that is true.
No I'm not confusing the two, I've definitely read somewhere than Ivy Bridge will require a new motherboard despite using the same socket as Sandy Bridge. It's all speculation though so it could easily be wrong, it might just be that you need a BIOS update.You can be forgiven for this since it's very unusual for Intel to make future processors compatible with existing motherboards however it is the case this time.
So the good news is that your current motherboard will accept an Ivy Bridge CPU when they are released next year, after a BIOS update of course.
A lot of people seem to be confusing Ivy Bridge (22nm, Socket 1155) and Sandy Bridge-E (32nm, Socket 2011); the latter uses a new and physically larger socket and is therefore not compatible with existing boards.
There is a hardware modification required on the boards to support IB, Intel recently updated all thier boards with new revisions to support IB.
