- 22 Mar 2009
- Cornwall
would a HD6950 be better then my 2 HD6850s in CF?
Looking at this chart, a 6850CF is quite a bit quicker than a 6950.
However, 6950 2GB does have the benefit of being a single card solution (so easier to overclock, quieter, less power hungry, never have any issues with crossfire support/scaling, can add a second card in the future) and has more VRAM (though if you are gaming at 1080p then 1GB is generally more than enough).
Personally, I would stick with your existing setup for the time being and wait for the big GPU performance upgrade that is coming later this year when the 28nm cards arrive.
Oh, and start bitcoin mining while the going is still good![]()
ok kool, 99% of the stuff i play i need vsync on so it wont go over 60fps anyways (think thats how it works). i guess this is down to my monitor?
the CF isnt really all that loud (i dont think anyways) and temps arent really an issue (except it seems to heat the front room up with the exhaust fans) so if there isnt anything to be had then i will save my pennies.
im also looking at possibly buying 3x17" monitors off a well known auction site, not the best res but thought i would give eyefinity a bash.
i do hope you are joking![]()
Aye, bitcoin has it's dodgy uses, but on the mining side their is not much risk at all. You mine coins within a well-known pool, you get the coins sent to your bitcoin wallet and then you sell them on a trusted exchange (like britcoin).
At current prices/difficulty and with an AMD card the return is quite a bit higher than the cost of electricity used, so it puts a bit of money in your back pocket if you run it for a while. As for extra stress on your PC, well it will stress your GPUs, but it doesn't stress your other components and so long as your GPU is running at a safe temperature then there is little to worry about there.
/Thread Hijack
Was browsing and after 5 minutes of reading Im deffo interested, especially since I have 6950 GPU sat in my PC right now. What kind of Work/Effort/Trade are we looking at here? A weeks worth of mining for £5?
With a 6950 and at current difficulty you are looking at 0.31 bitcoins per day (running 24 hours). At the current price of £9.80 to 1 Bitcoin then that means a week of mining will net you £21.28 (minus power costs).
so that is £21 for leaving the pc turned on? there is nothing else involved?
Yep, but don't forget your electricity costs (which are rocketing in the UK) - see above for a basic 14p per unit calculation.
This will only get worse over time as well, as the amount of Bitcoins earned depreciates over time vs. escalating energy costs.
Ok, I'm seeing more sense now. Especially when I put this into context that I earn more than this doing 1 hours overtime at work.
so why are people (noticed 2 or 3 so far) signing up to these forums and asking for quadfire mobos? surely if they are prepaired to shell out that sort of money there has to be something in it? or are these people just chasing a money for nothing dream and will end up being out of pocket with some equiptment that is OTT for real world use?
no single card on that list AMD or Nvidia outscore my setupso is it only going to be a silly money card (HD6990) that would be worth the upgrade?
A single card might be smoother, deliver better minimum and average fps, along with being potentially quieter. In terms of maximum frame rates, I think you are looking at spending more money to eclipse your crossfire performance.
