** EPIC DEAL IS EPIC - PRE-ORDER ONLY PRICE 22" LCD MONITOR with DVI £82.99 Inc. VAT!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK this is a truly epic deal, we have a 22" LCD Monitor from Philips and the specification is superb, check this:-
- 1920x1080 Resolution (True HD)
- 5ms ON/OFF response time (2ms Grey-to-Grey)
- 300,000 Dynamic Contrast Ratio
- DVI & Analogue Connectivity
- 1:1 Pixel Mapping
- 3yr On-Site Warranty
- Philips brand
Needless to say this monitor has a superb specification and is from a very well known quality manufacturer, yet will selling it for less than the cheap nasty stuff you see going around, so check this out:-
OcUK V-Line 221V2SB 22" Widescreen LCD Monitor - Black **Pre-Order ONLY Price** @ £82.99 inc VAT
** PRE-ORDER ONLY PRICE - STOCK DUE WEDNESDAY 29th JUNE - Price will increase on this date, Pre-Order NOW! **
You want the LCD flat display with the highest contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight-boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent black level and accurate rendition of dark shades and colours. It gives a bright, lifelike picture with high contrast and vibrant colours.
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc with the mouse.
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colours.
With sustainability as a strategic driver of its business, Philips is committed to using eco-friendly materials across its new product range. Lead-free materials are used across the range. All body plastic parts, metal chassis parts and packing material uses 100% recyclable material. A substantial reduction in mercury content in lamps has been achieved. We strictly adhere to RoHs standards which ensure that all hazardous material is removed.
On-Off response time is the period required for a liquid crystal cell to go from active (black) to inactive (white) and back to active (black) again. It is measured in milliseconds. Faster is better: lower response time means faster transitions and, therefore, results in fewer visible image artefacts in the display of transition of texts and graphics. On-Off response time is a more important measure in the display of business content like documents, graphs and photos.
Adjustable tilt is backward and forward movement of a screen on its base to achieve custom positioning for an ideal viewing angle and more comfort for people who spend long hours working on the computer.
Philips easy picture format control on OSD switches from the 4:3 aspect ratio to the widescreen mode and back again to match the display's aspect ratio with your content; it allows you to work with wide documents without scrolling or viewing widescreen media in the widescreen mode and gives you distortion-free, native mode display of 4:3 ratio content.
Philips designs and produces display products in compliance with strict Restriction of Hazardous Substances (RoHS) standards that restrict lead and other toxic substances that can harm the environment.
Features:-
- LCD panel type: TFT-LCD
- Panel Size: 21.5 inch/54.61 cm
- Aspect ratio: 16:9
- Pixel pitch: 0.248 x 0.248 mm
- Brightness: 250 cd/m²
- SmartContrast: 300,000:1
- Response time (typical): 2 ms
- Inputs: 1x Analogue & 1x DVI-D
- Optimum resolution: 1920 x 1080 @ 60 Hz
- Viewing angle: 176º (H)/170º (V), @ C/R > 5
- Display colours: 16.7 M
- Scanning Frequency: 30–83 kHz (H)/56–75 Hz (V)
- sRGB
Was [£114.99] Inc. VAT
Only £82.99 inc VAT.
ORDER NOW
I wish I had free shipping - would be extremely tempted to order this...
Would this monitor be good for gaming d'you think?
Grats on 4k posts Cook.
Damn good price that... would love some decent reviews as this would go nicely on my 2nd pc, been after a 1920 screen :O
I see your eyes could only concentrate on the nice lady but it does say Philips on the monitor :D
I would have thought the word "Philips" in the first line of the first post would have given it away too! :D
