AMD Catalyst 11.6 WHQL (8.861 May 24) - Download & Discussion
I do that as a matter of course anyway, but it didn't make any difference. :(
So have you tried 11.4 again to rule out the possibility of coincidence with EVE patches because there is many examples of numerous Alt Tab or minimised issues since 1.6 patch on the EVE Forum.
I upgraded from 11.4 to 11.5 and started experiencing the problem, so went back to 11.4. I upgraded this morning from 11.4 to 11.6 assuming the problem would be fixed but it's the same as with 11.5.
In short, the only obvious solution with nothing else on the system having changed is going back to 11.4 which obviously isn't ideal from a long-term perspective as speed boosts, etc come out with newer drivers.
Not had to do that in the last year at all with Installing over the top of official drivers, its only been the beta's that have given issues if doing that.
I never touch beta's, only release. I'm running CF 5830s though, not exactly top of the priorities list for being made to work properly, as far as I know it was one of the worst selling ATI cards ever. :P
Had a think & may of found a work around.
Goto the eve.exe right click & properties, Compatibility tab & tick Disable desktop Composition.
Would you guys open/close CCC a few times (from a shortcut not from the system tray) and check to see if multiple instances of MMLoadDrv.exe are left running in the background.
My text on firefox (sorted by turning off hardware acceleration). But MSN messenger is still fuzzy. It was fine with 11.2s.
Any way to fix this.
Almost anything that I open (Chrome, Firefox and even opening control panel) causes the PC to crash, I get vertical lines on the screen and it freezes there since installing 11.6.
I have reverted to 11.5 and it's stable now.
The drivers have been [not too cool] for the last few iterations I've had. I'm gonna remove them completely and go back to somewhere about 11.4 or earlier. BC2 crashes and stutters at an undetermined rate for me.
Case in point in this large image.
Note that's not my kit. I'm a recon with a CG, it's not my kit to have CG and SAIGA.
Seriously.
The drivers have been ******** for the last few iterations I've had. I'm gonna remove them completely and go back to somewhere about 11.4 or earlier. BC2 crashes and stutters at an undetermined rate for me.
Seriously.
And that's with your gfx card at stock ?
Well I haven't OC'd it but I believe it comes with a small factory overclock as its an Asus 5770 CuCore. Dropping it to reference clocks should make for improvements?
Well trying dropping the clocks & if it helps then its either down to heat or faulty card.
Different set of drivers can put different loads & stress on the GPU.
I'm getting the MMloaDrv.exe error when launching CCC profiles from a shortcut which I used to switch refresh rate and launching my DVB software and then when it exits resulting in many instances, also happening on the latest leaked 11.7's :(
Cheers, EP.
