** OCZ Vertex 3 gets a 60GB Makeover! ** Pre-order NOW!!
20 Jul 2009
Midlands
The OCZ vertex 3 has had a 60GB Make over with stock landing the begining of next month.
The Vertex 3 uses high quality Synchronous rather than the slightly cheaper Asynchronous NAND resulting in a faster, more reliable drive!
It comes in at just over £2 per GB but the performance boost over the previous gen Vertex 2E gives it the edge and the title of the Worlds FASTEST 60GB consumer SSD.
Order now to recieve at the begining of July :)
OCZ Vertex 3 60GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-60G) @ £128.99 inc VAT
As the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 550MB/sec
- Maximum Write: 495MB/sec
- Sustained Write: 455MB/sec
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £128.99 inc VAT.
ORDER NOW
So much for the "not going to happen" in the original vertex 3 thread :P
I'ts still protty expensive over £2/gb but for the speeds you get i guess it's acceptable :D
It will be interesting to see how fast these are compared to the 120GB and 240GB models. If they use 25nm NAND then they may only have 1 NAND die per channel, which significantly affects the speed.
Yeah, the 64 GB version of the Crucial M4 is a lot slower in write speeds compared to its larger brothers. I expect the 60 GB Vertex 3 will also suffer but what we don't know is by how much!
I'm personally not too bothered about write speeds on a SSD, the read speeds are where it's at which is why I went for Crucial M4 over the OCZ Agility 3 as it holds its Read speeds better.
