Asus & bent cpu socket pins
Man of Honour
12 Feb 2004
Herne Bay, UK
thanks to a wonderful courier service i recieved my p67 Sabertooth absolutley battered the guy i bought it off is trying to get compensation for it but i have heard most courier companies try and get out of it
my question is would Asus repair this or swap it out and if so how much ?
I'm just finding it hard to believe that was damaged in the post. How bad was the package when you received it?
i can say that wont have got damaged in the post. did the cpu socket have a cover on it. if so wont get damaged unless something hits the plastic cap hard.
If you RMA it I'm sure it will at least look at it so you probably wouldn't get very far.
If the board wasn't sent with the plastic protector fitted for the CPU socket then the sender has been pretty negligent.
A lot of e-tailers insist those are fitted if returning motherboards.
the package had a few dents in it and a very big one on a corner it did have a socket cover too maybe i just got conned that'll teach me from buying outside the OcUK forums :rolleyes:
