K13 Micra smells of petrol
4 Jan 2004
¯\_(ツ)_/¯
I've had this car for a few months now and it seems to have been fine but on Friday I filled the fuel tank until the pump went click.
The next day car stinks of petrol, inside and out, so I'm guessing there is petrol leaking from somewhere.
Also I opened the fuel cap again, and there was a hissing sound when undoing the cap.
I'm guessing there must be pressure in the tank, and when I take the fuel cap off the pressure is released.
So is it normal for a petrOl tank to be pressurised or should there be some sort of pressure release valve somewhere?
My old car was a diesel so I'm a petrol newbie! :o
What is the beat way of fixing this?
Edit I've just realised it's actually a k12 as opposed to a k13, apologies for any confusion....
Hiss is normal on some types of car/fuel filler so wouldn't worry, my wife's Yaris does it as does my Subaru, but our old Renaults didn't.
My filler even has a little warning on it about the pressure/hissing so I wouldn't worry about that.
Ok, thanks, so pressure in the fuel tank is nothing to worry about.
I'll see if I can get some photos as I think I may have found a fuel leak, I'm just hoping I don't have a hole in the tank...
Ok, this isn't the best photo but it looks to me like the fuel is running around the side of the tank:
And here's to confirm, it's actually leaking:
Not sure how it is on the Micra but on my Rover, the tank is actually two halves sealed together with a rubber seal.
Eventually the seal gives up and allows fuel to leak out. Had this once, not fun seeing your lovely fuel (I'd just filled up with V-Power :() escaping down the road :(
I think mine leaks a bit from the overflow if I drive a bit enthusiastically with a full-ish tank so might be worth investigating around that area, a quick google brings up a forum post of someone mentioning a seal around the overflow leaking.
Thankfully my leak doesn't sound as bad as that, it only drops occasionally but I still need to get this sorted as I'm sure it's not safe! :eek:
Thanks, that on the forum with the big MSC logo?
I'll have a check under the read seat tomorrow, hopefully I can find this overflow and check where the leak is...
I do drive a bit enthusiastically from time to time, so I guess when I've got a full tank, I'll try and take it a little more steady just like those F1 drivers do... :D
