Looks like the digits immediately either side of the decimal point have been erased (like many things in CPU-Z) to hide performance figures. So it could be just over 10 seconds or it could be just under 20 seconds. It had better be 10 if Bulldozer is even going to be competitive with Sandy Bridge in single-threaded applications, let alone Ivy Bridge or Sandy Bridge-E, because a Sandy Bridge CPU at 4.6 GHz will do a 1M Super Pi run in about 8-9 seconds!Super PI - 1______._______29s
Right....
Voltages are not comparable between different designs, right now we have no idea if 1.5V is high or low for bulldozer.
It's quite clearly not 1.29 s, there's two numbers blocked out...1.29 seconds? Not convinced at all
Sure, that's why I said it may not be applicable.
Still, 10+ second Super PI at 4.6 GHz is disappointing if this screenshot is accurate.
why so much voltage for 4.6ghz ???? my i5 2500k only needs 1.265v for 4.5ghz !!
OMG my kettle uses 230V, there must be something wrong with it!!11
