Need a CPU cooler?
26 Jun 2011
KFA2 GeForce GTX 560Ti EX OC Edition 1024MB GDDR5 PCI-Express Graphics Card
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
MSI P67A-G45 Intel P67 (Socket 1155) DDR3 Motherboard (Sandybridge) ** B3 REVISION **
BeQuiet Pure Power L7 530W '80 Plus' Power Supply
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
Cooler Master Elite 335 Case - Black
Final thing before I order this stuff in a couple of days, will the CPU need a cooler, or will it manage without one?
If you buy the retail version of the 2500k you will get a stock intel cooler included (oem does not come with one).
But if you want to get a reasonable clock with low temps you'll need to invest in a 3rd party cooler.
I would normally recommend the Gelid Tranquillo @ £25 but OcUk haven't got them in stock - so you may need to google.
Also, the Akasa Freedom Tower is worth a look @ £30.
If you wanted to spend less then then the Cooler Master Hyper 212 is a great bang for buck @ ~£20.
If you want relative silence and exceptional cooling then the Silver Arrow @ £50 is excellent (2 week lead time.)
cool, I'm getting one which will come with the cooler, can't wait to build this pc now, Thanks for all the help :)
For the sake of an extra £20 and a guaranteed clock of 4.3Ghz, without any fuss (1GHz more speed for free), i would really recommend you add the Cooler Master Hyper 212 to your order (or similar).
It will get you a respectable clock (worth more than the cooler) and keep the cpu cooler and run quieter when idle. Plus, the real bonus is that it will be a lot easier to fit than the intel's push pin method.
