click extend my resolution onto this monitor in the resolution settings page?
Personally, I have no experience with DP so I will let someone else help you rather than trying to guess and possible sending you off down the wrong path.
I will assume you have done the other simple checks of the resolution it is being set to etc, and the second screen isnt set to the wrong input or something.
what?
I dont have any ATI cards, so Ive never used display port and didnt want to guess at the fact of converters not working through other converters and then it be totally wrong and have wasted his time.
^ This.Anyway, did they revise the 590's in the end and release different versions?
Yeh no worries mate I appreciate you trying to help
I have just been trawling the other tech forums and I think I know what the problem is now.
It would seem that the MDP (mini display port) adapters convert the signal to the relevant type of port they are converting to.
So for example: I have a MDP to DVI adapter.
This has a DVI output signal.
However, I have then connected a DVI to VGA adapter which I believe changes the physical port but not the signal.
This means when I then connect my VGA monitor cable to this series of adaptors it is sending a DVI signal to the monitor when it is looking for a VGA one.
Therefore the monitor doesn't switch on but the PC detects it because the PC can translate the VGA signal.
It would be nice if someone out there could confirm I am on the right track as I am about to order an MDP to VGA adapter![]()
