Hi,
Can anyone tell me the optimal setup for fan placement in a Coolermaster stacker 832 case, at the moment i have this setup:
2 front intake - noiseblocker 120mm, gentle typhoon 120mm
1 rear exhaust - gentle typhoon 120mm
1 top intake - Noiseblocker 120mm
I also want to add the side door but that would mean buying a new cpu cooler (H60 probably) then i would be able to add 4 extra fans, what fans do you suggest for around £25 budget for all 4, quieter the better, thanks.
