KOTOR £1.74 get on it.
Bought it in either the Winter or last summer sale for a couple of quid. Haven't got around to playing it yet though.
Oh well, TDU 2 was a waste of money![]()
How so?
Is there a way to get KOTOR to run at 1920x1080? I got it last week @ normal price![]()
WS Resolutions
The game plays in Hor+ widescreen with the use of the UniWS patcher, originally developed by Wogg. The Patcher consists of two parts: Uniws.exe (which is the GUI interface and patcher), and the patches.ini file (which contains the game data to make the patch).
1. We strongly suggest making a backup copy of the KotOR executable (swkotor.exe) and placing it somewhere safe before modifying the game.
2. Download UniWS here: UniWS.zip. Unzip to a directory of your choice and run.
3. Choose "Star Wars: KOTOR (1024x768 interface)" from the Game dropdown menu, regardless of what resolution you want to patch to.
4. Locate the game's folder in the folder browser.
5. Enter your chosen widescreen resolution and click the Patch button. Note that widescreen resolutions lower than 1440x900 will not work! If you need to patch to a resolution lower than 1440x900 see the Notes below.
If the Patch button or resolution boxes are greyed out, you have either not selected the appropriate directory, or your version of the game is not compatible with UniWS. UniWS only supports the v1.03 retail disc or no-CD versions of KotOR.
6. The new resolution should now be available in the game's options menu. However, some people have reported the resolution does not show up. For this reason, we recommend setting the resolution in the ini file before starting the game. Open swkotor.ini found in the game's main installation directory and edit the "Height=" and "Width=" settings to match the resolution you specified in UniWS.
If the UniWS patcher does not work for some reason, please see the detailed explanation on how to edit the HEX in this forum thread.
Yay! Been waiting for the HOMM V pack to drop. Awesome sauce.
I already have Dark Messiah, though. If I purchase the pack "for myself", can I gift that one if I don't launch it?
