iPad 2 jailbreak (BETA) available
  • Thread starter Thread starter L33
  • Start date Start date
L33
L33
Permabanned
1 Apr 2003
Beta version, reportedly only working with wifi-only models. Hopefully a final release will be available later this weekend!
As we reported you yesterday that Comex is very close from finishing iPad 2 jailbreak with JailbreakMe 3.0. Now iPad 2 jailbreak 4.3.3 / 4.3.2 / 4.3.1 / 4.3 has been leaked from one of JailbreakMe testers who was able to jailbreak iPad 2 on the below video by downloading PDF file which is the exploit used to jailbreak iPad 2 with JailbreakMe 3.0.
For who can't wait for releasing iPad 2 jailbreak, you can go to this url from your iPad 2 "http://ryanlobbins.com/Saiz/saffron/iPad_4.3_8F191.pdf"
Note: This iPad 2 jailbreak is a very beta version and not compatible with all versions of iPad 2 (seems to work only on WiFi models) and this iPad 2 jailbreak may cause a crash in Safari. We don't recommend to try iPad 2 jailbreak unless you have enough knowledge about the operation. We highly recommend to wait for the officilal iPad 2 jailbreak release.
If you found this post useful, dont forget to click the +1 button =>
its like 1 GBP why dont you just pay for it?
I think (or at least hope) he means that he's paid for it, but needs the jailbreak to edit the plist file to make it work on the iPad, as by default WhatsApp won't run on the iPad at all.
yep, it wont let me run on ipad2. :(
Recently they've fixed the hole that let you edit the plist to work with iPad, and currently there is no way at all to run it.
I've knocked up a mobilesubstrate hook that spoofs WhatsApp's device detection methods, but I'm not able to test it until I can jailbreak my iPad 2 :(
